주요 콘텐츠로 건너뛰기
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 질문 전체 보기
Why can't I loosen the adhesive to remove the speaker covers?
I'm trying to remove the speaker covers on my HTC One M8. I heated an iOpener for 60 seconds and then let it sit on the speaker cover for 90 seconds. I then tried to remove the cover with a plastic opening tool but it wouldn't come out. What am I doing wrong?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Nothing you're doing wrong, they're just stubborn. I used a hair dryer on mine, the glue eventually softened up enough. New covers can be had for just a couple of dollars, so don't necessarily try too hard to preserve them (they'll likely not sit right again after removal anyway -- new covers come with adhesive attached, so they're perfectly flat, and just need to be applied).
Now, that said, there is a black raised lip around the outer edge. When I opened mine the first time, I didn't understand which side of that should come apart, and did some damage to it (nothing functionally wrong, but cosmetic, and it bugged me). The lip goes around the speaker covers, but no deeper, so to separate from the metal back, go around the outside of the lip, not the inside. This is probably obvious, and I was just being dim, but, just in case, keep an eye out, as it's incredibly easy to break off pieces of that ridge.
One more unsolicited tip I got off an unrelated repair video: the power button isn't attached to anything, and is obnoxious to try to replace once it falls out, but a small piece of tape over top of it keeps it in place, so it's no problem.
Good luck with your repair! :O)
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Matthew Eng 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 215
