주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Why can't I screw the bottom right P2 screw back in place?
Hi Guys! First of all thanks for all the support this great community provide.
I've got an issue with the loudspeaker of an Iphone 5c I'm fixing - sometimes it stops working- and I hardly suspect this is due to the lack of the bottom right P2 screw, which can't hold in place the speaker onto its contacts.
I've already bought new screws to replace the missing one, but when I've tried to screw it in place, it couldn't fit (I've also tried moving the original left one, into the right hole, but with the same result).
What can I do? Is there a replacing part for the P2 screws housing?
Thank you all!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Check the front display assembly at the lower part. There are two screw holes for the pentalobe screws. If one or more is missing, the missing sides will just have the screws spinning to nothing.
If they are both there then you will probably need to poke something through a bit then close then put the screen back in place and try again.
There is no easy replacement for the P2 pentalobe screw holes as they are part of the front display screen frame.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks for your answer! Is surely helpful :)
Luckly the display assembly seems to be fine, even 'cause the issues still remain without the display assembly...
May it be due to the lightning connector housing? in that case, is there a part just for it, or should I change all the connector?
I doubt the dock connector would be at fault because it shouldn't obstruct where it goes unless the whole phone housing is badly damaged / bent at the bottom part.
댓글 달기
귀하의 답변을 추가하세요
Rocco Lorusso 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 112
