주요 콘텐츠로 건너뛰기
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
218 질문 전체 보기
Back-light fuse pops as soon as the battery is connected.
I received an iPad with a back light issue. usually i would pin it down to the fuse/filter. but every time the fuse is replaced i see a puff of smoke come from it as soon as the battery is connected. I have additionally replaced the IC/diode and the coil (I know its not the coil... but still). has anyone else encountered this if so is there a solution.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Check the camera IC's. I had a heck of a problem with iPad Mini 1st gens popping filters and it ended up being a bad camera IC. I was popping them when I disconnected the screen and didn't figure it out until it was too late.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
hmm ok. i will check if i can find the camera ic. although i can't see how the back-light would be connected to the camera.
댓글 달기
귀하의 답변을 추가하세요
Thomas Edwards 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 78
