주요 콘텐츠로 건너뛰기
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 질문 전체 보기
Why can't I get a display
I recently replaced my iPad 2 digitizer and even thought with a bad digitized I still got a working screen with light so now that I replaced it I'm not getting a screen I would do a hard reset but there's no way of knowing the home button is working since it has no cords attached to it or anything I'm really stuck here please help but I know it's on cause if I plug in the charger I'll get the charging sound
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
I would double check your LCD connections. It sounds you have a loose connector not making good contact. But make sure you power down the device or disconnect the battery before checking your connections you don't won't to short anything out.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I let the battery die down and when I plugged in the charge the battery sign comes up like when it's dead so I know it's not the lcd so I let it charge but it seems now it will still not show the screen but I plugged the charger in again and I can hear the charging sound I'm not sure what to do please help
After you let it charge do you see any image on the screen? if not during your iPad repair the blacklight components could of burnt out just by what you're describing.
댓글 달기
I think im having the same problem. While charging a dead battery the screen is bright and functional. However it goes completely black, no activity at all, after booting. Any ideas?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
lateef ambali 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 89
