The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
634 질문 전체 보기
Virus problem in phone
Hey
I have problem in my phone and i want the solution for this problem and without formatting without flash
THANKS
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
5개의 답변
선택된 해법
In the Google store do a search for Avast Mobile Security or AVG. you can also try Avira as well
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
1. Take battery out.
2. Put it back in.
3. Power on phone.
4. When it's at the Samsung animation boot logo hold the volume down and up button and repeatedly hit the touch sensitive buttons.
5. Keep doing this until you get a 'Safe Mode' text at the bottom mode
6. Then release all keys and navigate to phone settings, applications and look for the 'System Update' app which should be located under downloaded applications. Uninstall this application and restart your phone.
7. Your phone should boot up and be out of safe mode and the virus should be gone.
Usually this application is disguised as 'System Update' but could be disguised as another application.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
No is not working that safe mode
의 답변
의견 추가하세요
go to the Google store and look for a good Malware scanning utility. It is rare for a phone or tablet to get a virus but not impossible because anything that can connect to the Internet can become infected.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Send me good application for Virus scan ok thank
의 답변
의견 추가하세요
The wifi range is not good
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Can you please describe the file attributes of the file that might be disguised as system update file. I actually have 2 files called system updates. One is 22.56mb and the other is 725kb. I have emptied the caches and done everything except this and reverting back to the factory settings. Id rather not if this works. Thank you in advance.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
taha elattar 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 25
전체 시간: 2,145
