Why touch function not working - becomes worser -?
Dear experts,
first of all, I want to apologize for my bad English.
Before I start to write my concern here in this community, I did a lot of research.
I own an iPhone 6 Plus. Over the last 8 weeks the touch function on the display have become worser and worser.
Hopefully, somebody can figure out the reason of this error.
1. [touch working >99% of all times] Approximately 8 weeks ago the display's touch function freezed sometimes, but with a slight knock on the device, the touch function worked again.
2. [touch working 97% of all times] The problem developed stronger, I had to strongly hit the device into my open hand to make the touch funktion work work again..
I assumed the display causes the error (because it was a little bit cracked), thus I exchanged it. Now I use a brand new display unit.
3. [touch working 50% of all times] Same error with the brand new display. The touch function works only 50% of all times. It's probably not caused by the display unit.
I found out how to temporarily fix this error:
- I bent my iPhone by pressing on the upper top right corner down while pressing the back of the device up, the touch function works while I do this.
- Opening the device and strongly press the area around the processor. While I do this, the touch function works. As soon as I relieve, it does not.
- When I carry my iPhone 6 Plus in my pants pocket, after that the iPhone touch function sometimes works or not . MAybe due to vibrations the phone might work or not.
Right now touch function is working 10% of all times. I fear this is going to 0% soon.
I really have no idea how to fix this problem.
It's definitely not a software issue, I did a hard reset (DFU).
I googled for Touch IC (not Touch ID, its Touch IC).
Maybe somebody knows if this will fix the problem !?
좋은 질문 입니까?
