메인 콘텐츠로 스킵하기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1550 질문 전체 보기
iPhone screen went black but is on
Hi,
I was using my iphone 5c just a moment ago and was on facebook, then the phone locked up, i couldnt do a thing, then the top quarter of the picture started to do almost like a dissolving thing so that the picture started disappearing, then the screen went blank,
Here's the steps i have taken to resolve this.
Tried turning it off using the power button - Did nothing, screen is still black
Tried holding the power button and home button together - Did nothing, screen is still black
Replaced the screen - Did nothing, screen is still black
Tried plugging it into the computer and doing a reset - Did nothing, screen is still black
However, i can ring the phone and it rings.
So whats the problem? why has my phone randomly died? could it be that the gpu chip has committed suicide?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
선택된 해법
You did everything right in terms of troubleshooting. It sounds like the LCD has gone bad. Luckily, this is is a relatively easy fix if you take a look at the iFixit guide. This will also provide the link to the kit you will need in order to do the repair if you do not have the tools.
Just so you are aware, the part does not include the home button or the front camera assembly. These will need to be transferred to the new screen. Be sure to use heat to remove the button and camera because simply pulling them off can tear the cables.
Home Button Guide
Front Camera Guide
iPhone 5c LCD and Digitizer 이미지
안내서
iPhone 5c LCD and Digitizer Replacement
난이도:
보통
30 minutes - 1 hour
iPhone 5c Home Button 이미지
안내서
iPhone 5c Home Button Replacement
난이도:
보통
1 - 2 hours
iPhone 5c Front-Facing Camera and Sensor Cable 이미지
안내서
iPhone 5c Front-Facing Camera and Sensor Cable Replacement
난이도:
보통
40 minutes - 1 hour
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
h1cks2002 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 189
