주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2686 질문 전체 보기
black screen after screen replace
hello
i have been repairing phones/cameras and anything else i can get my hands on for many years and this is the first phone thats giving me a lot of trouble. i have tried a few different screens and all i get is a black screen. i can see the apple logo when i force a reboot and i had a brief flash on light on the screen when i connected a charger. i have cleaned all the joints and connectors.
anyone have any ideas on any other tricks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
This sounds like a issue with the backlight ic on the logic board. I'd wait for others to comment as they probably know more about this kind of issue.
is there any way you can get a light behind the screen? if the backlight burnt out, using a light behind the screen should help figure out if theres nothing showing on the screen or if the backlight is having issues.
댓글 달기
답변 1개
가장 유용한 답변
The other few things to check would be the 2 connectors that control the display and the backlight. Those connectors can bend quite easy, verify that they are flat before placing them on the logic board and work from one side to the other to help ensure correct seating. You mention the screen flickered or lit up? Apple can be funny with diagnostic codes. Sometimes the code is displayed via a certain color millisecond splash screen "flicker". Also, the proximity sensor and ambient light sensor can be damaged easily in those repairs and may keep the device from booting to protect itself. Occasionally by disconnecting just the flex cable from the logic board that contains those sensors and the front facing camera, will allow it to boot fully and confirm the issue. Best of luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Can confirm this, have damaged the proximity sensor a few times causing the phone not to boot up until unplugging the front camera assembly ribbon cable.
This was not cause of my problem and phone is acting same way. Anyone have any other troubleshooting ideas?
댓글 달기
귀하의 답변을 추가하세요
ian 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 185
