Botched Disassembled, won't power back on!
Really stressed! So my lock-button was jammed, and I was fed up of using touch assist, so I took out the screws by the charger port, and tried to disassemble the thing. Some of the black plastic internal frames snapped, and that's all I can recall breaking! Now, when I realised how complex the inside was and gave up trying, I can't completely re-seal the phone and it also won't turn on! HELP!
좋은 질문 입니까?
Do you mean the plastic internal frames of the front display assembly?
Where did you start opening the phone from the bottom or the top?
Did you work your way up and lift the screen up to like a 45° angle with the bottom part of the screen?
Can you see if any ribbon cables snapped?
Ben 의
