주요 콘텐츠로 건너뛰기
The Visual Land Prestige Elite 8Q is an 8-inch Android tablet produced by Visual Land.
69 질문 전체 보기
My Tablet is Stuck on a Black Screen
As the title says, my tablet is stuck on a nonfunctional black page with only the back button and taskbar. (It's similar to the lock screen.) I know it is not just my lock screen due to the fact that my taskbar is functional whereas on the lock screen it is not. I also have noticed that my tablet is working in the background. When the screen is powered on, I catch a glimpse of what app is open for an 8th of a second but then back to the black screen. I have tried rebooting several times (including safe mode) and I even called Visual Land Support. The only solution offered was factory reset. I have used all 11 GB so that's not really an option for me. I was hoping you smart people of the Internet could assist me with my serious problem. Thank you very much, and have a great day.
Update (07/13/2016)
The tablet was not having an internal problem. Apparently, a micro SD card I had inserted caused the tablet to malfunction. I'm not sure how something like this is possible, but it is fully functional as of now. If someone else is having this same problem with their device, I recommend first powering down the device, taking the card out, then powering the device back on. This should fix the problem if you have the exact factors of my issue.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Dear friend,
i had read your issue, the exact solution is reset,
but you can just try to remove battery connection to the board ( then keep it disconnected for at least 30 minutes) then reconnect then turn on it..
good luck my friend
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
And by reset you mean hard reset, correct?
yeah, if hard reset not fix, you need to flash firmware,
Flash firmware? How do i do that?
댓글 달기
귀하의 답변을 추가하세요
Protomon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 878
