RCA Android tablet with detachable keyboard, identified by model number RCT6303W87DK.
362 질문 전체 보기
Ran over it with wheelchair
Shattered about an inch of the upper right hand corner of the screen & one long thin crack across the entire screen. It still turns on & goes to the start page but does not respond to touch at all. Have not tried keyboard was afraid to tip it thinking all its' inners would fall out. Also it will power down to the point the 'power off' popup comes up but again touch doesn't work. It does turn itself off at the designated time, so it seems it's not totaled. The only thing I've done is take out all the tiny screws, I couldn't get the back off easily & didn't want to force it. Any efforts to help are certainly welcome, I truly need it. Thank you
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
3개의 답변
선택된 해법
Here's a video on how to replace the digitizer: https://www.youtube.com/watch?v=V-bFHycv...
Here is a source for the part: http://www.actablet.com/digitizer-touch-...
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
해당 답변은 원래 다른 질문에 답변 된 것입니다.
If there is a way to change keyboard settings it will probably either been in the control panel under devices or accessibilities. Look up how to turn on/off "Sticky keys" in your version of whatever OS you are using
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
It sounds like the touch screen digitizer has been damaged. Not sure if for this device you can replace just the touch part or you have to replace the LCD/touchScreen all in one piece but it sounds like if you get the screen replaced it should be good as new. Also the innards won't fall out so connect it to the keyboard. If the keyboard and mouse still work the you can either not use the touch screen or just get the screen repaired
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Judie Scoville 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 351
