Water runs constant when powered on.
Power on my coffee maker and the water won't stop flowing thus there is no heating of water and no much needed cup of coffee. Any ideas? Thanks
좋은 질문 입니까?
좋은 질문 입니까?
If the water is not hot, it is likely your boiler’s water level probe.
The cause of this is usually scale/mineral buildup on the probe. An out right failure of the probe could in more rare circumstances be the issue.
Unplug your machine. Empty the water reservoir. Then fill your water reservoir with vinegar to the “Max” line.
After that, have at least three big glasses or containers and plug your machine in, letting the vinegar get into your system, specifically your boiler where the water level probe is located. When the vinegar in the water reservoir looks like it is nearly at the bottom of the water reservoir level, unplug your machine and let it sit for at least 4 hours.
After 4 hours, dump out the vinegar remaining and rinse your water reservoir thoroughly and then fill it with water. Get your 3 huge cups or containers again and plug you machine in and let the water displace your vinegar from your boiler.
At the point you plug your machine in, it might just start working again and not pour water. If the water just flows right through, you might have to do a second or even third vinegar treatment depending on how bad your mineral problem is.
Good Luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 101
