주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iTunes won't detect iPhone
Hi Everyone,
My phone is stuck on the apple logo. I could only get it to restore, but iTunes won't detect. My lightning cable work. I assume my dock connector works as well since I got it to restore mode. Any Ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개:
Is your lighting cable an apple product? If it is a no-name brand that might be your issue.
Did you try DFU (Device Firmware Upgrade) mode yet?
Yes i am using the original Lightning cable that came with. I can't get it to go on DFU mode. I could only get to restore. When I am on restore mode I can't get it to detect on iTunes
How many drives do you have on your PC. I have too many and sometimes Windows 10 will not detect anymore drives when I connect more on my system. If you have alot try disconnecting any external drives off you system and then try again. If you are using an apple computer please disregard.
댓글 달기
답변 1개
Just because the phone says it's connected by the lightning cable doesn't mean it actually is. I had an iPhone 4s with a similar issue as yours. It ended up being caused by a damaged diode on the mother board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Eliel Arredondo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 129
