주요 콘텐츠로 건너뛰기
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218 질문 전체 보기
Why isn't my phone charging anymore
Yesterday morning my phone was charging and it was at 100% . Ok so later in the afternoon I tried to charge it and it wasn't working. So me and my sister tried to fix it. So she got a bobby pin, got a flashlight, looked inside of the port and the port was down so we got the bobby pin and stuck it in there to pull it up. After we did that we put the charger in and it still didn't work. So I prayed that it wouldn't die and it died so now I have nothing.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Don't worry! It could always be your charger block or cord. Double check that the phone will not charge with another cord set.
Trick 2: Use a toothbrush that has been dipped in 91%-100% isopropyl alcohol (tap off the excess) and try to clean the port as best as possible.
If this does not work, based on that I cannot find any repair guides on the web right now, I'd recommend taking it to a local repair shop.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
This one is definitely in the category of planned obsolescence : http://www.pcmag.com/article2/0,2817,248...
But you can get into it: https://www.youtube.com/watch?v=ziC8o3oB...
And several more guides here: http://www.waoweo.com/zte-zmax/disassemb...
댓글 달기
귀하의 답변을 추가하세요
Azzareya Huerta 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 414
