주요 콘텐츠로 건너뛰기
Portable wireless speakers from Logitech released in 2013.
70 질문 전체 보기
My Megaboom won't turn off, it stopped half way through a song
My Megaboom won't turn off, it stopped half way through a song and now I can't do anything with it. It have only had it since Christmas, I don't use it that often, so frustrating. I have tried rebooting it by pressing on/off button and volume down button, nothing happens. I have connected it to my computer - nothing happens..what is going on??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
My ue MEGABLAST wont turn off its fully charged and won't connect to my bluetooth
댓글 달기
답변 6개
가장 유용한 답변
I've had a similar problem with my UE boom 2. Found that if stop the music on phone, then turn UE boom off, then turn it back on and restart the music it will work just as normal. If that doesn't work turn your Bluetooth off on your phone( or just restart it). That solved my problem
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Have had my mega boom 3 for 2 weeks and similar problem. I had to turn off my connection to Bluetooth to get it to disconnect, but can’t get the power button on the speaker to tune off. I have tried pressing the down volume and center top button to no effect. Do I need to return?
댓글 달기
I had the same problem, I just waited for the battery to die then plugged it in and now it works perfectly fine
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
It sometimes happens. Crazy but yes it should fix once battery drained and recharged. I am waiting as we speak for the battery to drain.
Will update after I have recharged etc
댓글 달기
Me too mine cut out halfway through a song. I tried everything to fix it in the end had to wait for the battery to die then it just started normally.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Me too.... I'm sad about the latest round of EU Megabooms. They were better 10 years ago.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I got the same problem, I might be partially to blame as I hadn't turned it on in over a year, battery dead, charged it and forgot about it so it charged overnight, that might be why it won't turn off. I think sometimes early on the battery memory can get confused and it you have to let it die and recharge it, that's what batteries are designed to do, die and be recharged, so a complete cycle of both can reset the memory.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I cannot get my iPhone to find my megaboom in my Bluetooth…I thought maybe it was old technology in the speaker. Any advice to get it to show up? I did fully recharge it…but still doesn’t show.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
dunndearman63 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 25
30일 전: 144
전체 시간: 11,619
