주요 콘텐츠로 건너뛰기
Why is the battery light flash but won't charge and turn on?
Hi! So the power button lights up but the screen is black. I plug the charger in but the battery light just blinks orange. Not sure if its the charging port,the charger or the laptop. Is it an easy fix?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
I would first measure the charger with a multimeter and see if you get the correct voltage. Then measure the amount of amps the laptop is drawing from the charger. Because the battery light responds when you plug in the charger it is unlikely that the charge port is bad. What I am guessing is that the charging IC is bad, if you know the charger is good. To verify, you will want to insert a charged battery and see if it powers on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Amy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,331
