Nexus 7 doesn't power up no matter what
Before you guys suggest the 30secs power button hold, or the volume power button combo, or reconnecting the battery, or removing the battery for 2 minutes etc... I've already done all those things and more.
Here is what happened, a few years back my nexus 7 starting glitching. It got slower and would heat up some times with overuse. Then it turned off because I forgot to charge it and it refused to turn on again. I spend then next 2-3 days looking all over the net for solution and then it hit me, the nexus that is, it was sitting on my desk and as I tried to reach for it I dropped it from a height of 30cm or less. Suddenly a miracle, the nexus 7 opened up. I was so happy that I started using it again non stop and as I charged it to full battery I was sure it would never do it again, good nexus. Then the power went off as it drained the battery at night while I was asleep, and so once more it would not open.
After that I got desperate and tried softly dropping it from 20-30cm... It worked once but then back to 0...
Here is what I know, the battery works and it is charging normally. There is a buzzing sound when it has power (charging the battery or with the battery charged and connected) it comes from under the metal shield just below the battery connector. Now I know that it might be a loose connector that is causing the problem but dont know how to check for it and If I should go for it or if its something else. Anyways if anyone can help that would be great it's been years since I havent used it although it once opened (black screen though) since it says on the playstore that it connected recently probably one of the times I was trying to open but saw no response or so I thought. Maybe it's the screen connector?
좋은 질문 입니까?
댓글 2개
Did you ever get this fixed?
mike 의
Nope sorry, probably a component malfunctioned. Might have a burned capacitor or something. At first it was just a cable issue but the I guess I overcharged or something and it bricked.
xgarbo 의
