주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
3376 질문 전체 보기
New battery not charging
I replaced my battery with new. All went well, plugged in charger and apple display went on for a moment and then out. Reconnected the new battery thinking maybe I had not fully connected it. Same result. Reinstalled the old battery and the phone starts as usual and charges and remains on after charger is disconnected. Reinstalled new battery and again no progress. Is this new battery bad? I have left it to charge quite a while 15-20 minutes and still no apple start-up display. If I disconnect the small cable and reconnect it sometimes but generally not, the apple logo will come on, but only for a few moments and then it disappears and that's it. Any ideas?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글:
Probably a faulty battery.
Update,
Ifixit.com sent a new "replacement" battery and that did the trick. Great customer service and response. Once installed the battery showed a 40% charge. Followed packaging advice and allowed the phone to discharge the battery to 10% and then recharge to 100%.
All good at this point.
의견 추가하세요
답변 2개
가장 유용한 답변
Faulty battery, buy a new one. Just know your phone is 4 years old and no longer in production, so the batteries aren't either and most likely the ones you buy are cheap knockoffs, or the real deal that haven't been charged in 3-4 years.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
Well, I'm not so confident in that idea, since the battery was recently purchased directly from this site.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Then I'd contact iFixit for a replacement then.
의견 추가하세요
귀하의 답변을 추가하십시오
flywheel 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 132
