Why is my ds lite not reading cartridges I put in it?
My ds lite is not reading the ds or game boy advance cartridges I put in the slots.
좋은 질문 입니까?
좋은 질문 입니까?
you may have corrosion on the copper pins in each slot. To fix this, gently apply rubbing alcohol to the corroded pins with a cotton swab. Although it is unlikely that both of the slots would have this problem, it is worth a shot.
해당 답변은 도움이 되었습니까?
If the above doesn't help get rid of the corrosion, try this. Get a sheet of 600 grit wet-dry sandpaper and use that to lightly sand the metal contacts.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 487
