주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
Display works, touchscreen doesn't.
Okay, so I'll start from the beginning. Just got my iPhone a month ago, had a life proof case. I went into a pool with it (stupid me) it got wet. It worked for around 2 days after and then my touchscreen stopped working. I did a restore and it started working again but failed a couple minutes later. The only thing that gets me confused is how the display is perfectly fine yet my touchscreen doesn't work, I feel as though there is a way to fix it but I haven't found anything on the web about it. All buttons work, fingerprint works but can't use it without the passcode. I've tried checking and cleaning the connectors of the display but no luck. Any tips? do I really have to buy another display even though mines working perfectly fine except for the digitizer?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Just saw a video after some reasearch about a guy cleaning the connectors with a tooth brush and ipa, going to try it will post results.
no luck, display still works, touchscreen nope
댓글 달기
답변 1개
선택된 해법
My recommendation is to get a professional to perform a water treatment on it asap, as the mother board probably got wet, also the digitiser connection (on the Screen side) can get damaged by water getting in the earpiece speaker hole so a new screen may be needed. I would still recommend getting a water treatment done.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
roswell saldivar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 14
전체 시간: 151
