rear brake drums will not come off
how do you get rear drums off
좋은 질문 입니까?
Mike,
Most brake drums will have an adjustment wheel inside the drum, accessible from a slot behind the wheel. You must let the brake shoes in for the drum to loosen. After you do that, it should pull right off.
Reference this prior question for a guide and general diagram on how it works.
Let us know,
Frank
해당 답변은 도움이 되었습니까?
Frank, you and your expertise have been missed around here ;-)
Thanks Mayer. I have been a busy man in this last year, which is a good thing.
I was just looking at that old question. Two of the links are dead. So here is a link to an exploded view. It will be the brake adjuster screw that needs to be loosened.
If they are not totally froze up...adjust the brakes DOWN (or in) so they are not so tight. TAP all around the drum, (not hard) with something hard, large screwdriver handle, wood, something to help loosen the built up dust. They should come off if they are not totally "welded" together. Good luck
해당 답변은 도움이 되었습니까?
If they are totally welded how can you get them to release?
Make sure your e-brake is not on. That will tighten the grip the shoes have on the drum and make it next to impossible to remove. Assuming that wasn't the problem...
A lot of brake drums have threaded holes on the face near the lugs. These holes are there to put in jacking screws for drum removal. Find one or two screws that fit the threaded holes and use them to push the drum off.
If there's no such holes, well, get a deadblow hammer and start banging. Penetrating oil from your local auto parts store will also help.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 6
30일 전: 22
전체 시간: 24,707
