주요 콘텐츠로 건너뛰기
A five and seven-seat MPV produced by the French automobile company Citroën. First produced in 2006, with the 2nd generation's production beginning in 2013.
C4 Grand Picasso, aircon mode change doesn't work
Hi,
Citroen C4 Grand Picasso 2010, 1.6L, EGS.
The air stopped blowing out of the outlets, the garage says the engine that changes the mode (top, middle, bottom) has a broken piece of plastic but they need to replace the whole module which costs above $1,000.
Anyone know where I can get a part?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
Comment changer ambryage
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi. It can also be the the motor. Or connections there are lose like ours. It's only few bolts and some plastic and the blower motor is out because it was totally rust. We got told around 400$ for a new. Got it out no rust. Just lose connection. If I was you. I would try take it out. Check it. It's in passenger sider.
But we still have problems it Will not run. So sometimes I need to move the connection. And then it's start.
I hope it would help. 1 time I do something like this.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
This is a very old comment, luckily I do not own the car anymore.
It was the plastic that connects the motor to the lever that moves the vent control, so that the vents where in closed position all the time.
Eventually found that piece of plastic out of a scrapped car and replaced. $10 for the part, instead of $1000
Ok I didn't see the date on that post.
Have a great day
댓글 달기
SIM , é uma peça de plástico fraca trabalhando com um motor forte , basta fazer o reparo e tentar deixar mas forte e resolve-se o problema , tenho um com o mesmo problema e já estou vendo uma oportunidade para fazer
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
yonatan passwell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 70
전체 시간: 2,194
