주요 콘텐츠로 건너뛰기
Won't spin after I changed the belt
I have a heavy-duty Kenmore 70 series washer that I replaced a broken belt. I've put it back together and now it won't spin though it sounds like the motor is spinning the drum and agitator don't. Some oil did leak out of gear box
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Most Frequent Causes for Vacuum cleaner belt keeps breaking
Cause 1
Brushroll
If too much hair, string, or lint is caught in the brushroll, the brushroll can get stuck. If the brushroll is stuck, it will put too much strain on the belt and may cause the belt to break. Remove the brushroll and clean out any debris from the bearings. After replacing the brushroll, make sure that it turns freely.
'''Most Frequent Causes for Vacuum cleaner brush not spinning
Cause 1'''
Belt
Inspect the belt to see if it is broken, stretched out, or out of place. If the vacuum cleaner belt is broken or stretched out, replace it.
Cause 2
Drive Belt
Inspect the belt to see if it is broken, stretched out, or out of place. If the drive belt is broken or stretched out, replace it.
Cause 3
Cogged Belt
Inspect the belt to see if it is broken, stretched out, or out of place. If the cogged belt is broken or stretched out, replace it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Are you sure hat the belt is on correctly as it sounds as if the tensioner is not doing it's job.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Leo Abad 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 23
전체 시간: 1,252
