Display rear aluminum separation
The rear aluminum panel on my display is separating what kind of glue is better to re-attach
좋은 질문 입니까?
좋은 질문 입니까?
What I'm trying to determine is if it is just the adhesive or if the inside frame has broken. When they break it usually is on the left hand side about an inch up from the bottom. Yours may have broken which allows the display to flee and pulls the glass loose on the bottom. This may also just be a case of adhesive failure that can be fixed with a heat gun and some pressure. If you can post a couple of pictures if might help to determine the cause. Has the screen ever been replaced?
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 169
댓글 2개
Is it separating in the lower lefthand corner?
mayer 의
at hinge from end to end just lifted
marcheroux 의
