Display connection is covered in tape
The display cable is covered all around with a yellow transparent tape. It is not attached to the socket. When i peeled the tape back the cable came with it. Could this be the source of my display problem. And no this has never been tampered with. I do not understand how it worked before. Should i connect and try before i proceed with display replacement. The mac was dropped and display went out.
좋은 질문 입니까?
댓글 2개
Can you give us your exact model info. If you don't know you can check it here using your systems S/N: EveryMac
Dan 의
That machine has been worked on. Apple did not do that.
mayer 의
