주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Can't get past the Apple logo at startup...
So I replaced the Lightning Connector and Display panel on my son's iPhone 5c. Now the iPhone won't boot up?
It gets stuck right after the Apple logo appears... then there's a series of lines of type that appears (like the kind you would see on a PC when you're on the "boot-up screen")...
The lines are so small I can't really read what says but it goes through several checks and gets stuck at the same place/line each time.
Has anyone seen this before?
I'm wondering if I damaged the Logic board or if it's a battery issue. The phone does get really hot... and I had trouble removing the battery and those combative adhesive strips (even with 4 or 5 rounds of heat bags to soften the adhesive)!!
Update (07/28/2016)
So... I found out that one can do a "Recovery Mode" process using iTunes. The wanted to fix itself but it failed to first Update (saving your content) and secondly... it wouldn't even do a full Restore (erasing everything and reinstalling a fresh OS)... it kept resulting in error codes 4013 or 4005 each time I tried Recover Mode.
I'm so bummed.
It's my son's phone and I'm a truck driver and leave tomorrow for 2 weeks. My wife works too (6 days a week and does several different shifts) so my son needed the phone for communication with us and emergencies. I don't have the money to replace or even fix this phone! I'm at a loss!!
A Logic board will run me $150 and a new battery costs $30. I just spent $100+ and it still doesn't work...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
Can you post a hi-resolution picture of the error?
try removing the camera flex and power flex, prompt to boot with cable
댓글 달기
답변 1개
선택된 답변
Hi, if it is coming up with text on the screen, this tends to relate to the front camera flex, try unplugging that and see if it boots, if it does, the front camera flex needs replacing. :-)
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
beat me to it ;)
Thanks guys... I'll have to try it when I get back from my road trip...
I do try @ethanchow00 ;) haha
No worries Andy! Let me know how it goes!
댓글 달기
귀하의 답변을 추가하세요
Andy Kotz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 165
