주요 콘텐츠로 건너뛰기
The Canon Pixma iP3600 is a compact inkjet photo printer that weighs 12.3lbs and is 17.0”(W) x 11.7”(D) x 6.0” (H). This wired printer was released as part of Canon's Pixma series in 2008.
24 질문 전체 보기
The rollers are not pulling the paper through for printing.
The rollers are spinning but the paper is not being pulled forward for printing.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 3개
I'm also having this problem with a Canon MG4100 , I'm having to push the paper through to get it going, pain in the a**e ! Any advice would be much appreciated.
The rollers is not pulling on top feeder, can anyone help edible canon printer
Solution is not to buy a printer with Canon on it. Replacing rollers is more practicle but these are disposible printers so not made for replacing parts only the garbage bag in the can.
댓글 달기
답변 2개
가장 유용한 답변
I suspect the rubber on the rollers are worn out so they can no longer grip the paper.
You can spray this on the rubber and it will work again.
https://www.amazon.com/Max-Professional-...
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks I'll give it a try
댓글 달기
Canon printers have a function where they can self-clean their rollers. It might need further service, but it's worth a shot. See https://support.usa.canon.com/kb/index?p...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Why cant you just replace the %#*@ things?
댓글 달기
귀하의 답변을 추가하세요
childcare513 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 16
30일 전: 27
전체 시간: 4,752
