주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
598 질문 전체 보기
Ghost touch + bottom portion of screen/home button unresponsive
I recently got a request to fix an iPad Air, the clients bag was damp and he put his iPad in it and the whole thing basically broke down.
1)ghost touch
2)every time he tried to charge it would turn on turn off if it made it to passcode screen it'd restart
3)home button no longer worked
After I opened screen I unplugged flex cables and cleaned them with isopropyl + also I stopped the ghost touch by using electrical tape to secure the flex cable on the digitizer down and fighting the digitizer cable connector to itself by wrapping electrical tape around it
Still after those this it the problem I ran into
4)bottom half of screen still no longer responsive
5)home button still unresponsive
What the !&&* is happening. This isn't anything like an iPhone repair.!?!?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 2개
The problem you are having is very simple, it is the issue of the digitizer not being grounded properly. Use Kapton or electrical tape to make sure it is grounded properly and you would not have the issue anymore.
iPad Repair
해당 답변은 도움이 되었습니까?
점수 0
댓글:
i tried this, but i still cant use the home button nor the bottom half of my screen
If even after grounding you cannot use it, it sounds like a defective digitizer.
Fix Ghost touch on iPad
의견 추가하세요
The scary part of the issue is the damp bag.
On most devices the simple answer is to try a new digitizer. But the digitizers for Air 2s are still really expensive. If its not the digitzer, its probably water damage on the board, which is a near death sentence. So...you can try a new $200 digitizer and see if that fixes it or you can inspect for water damage and risk going down a rabbit hole.
I don't know which option I would pick first....
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Dairius 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 1,022
