주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 Apple MacBook Air 중 더 작은 노트북.
122 질문 전체 보기
MacBook Air mid 2013 exterior screw pentalobe size?
I'm attempting to swap out the SSD on my Macbook Air Mid 2013 (non-retina). I ordered a set of pentalobe screws from Amazon to let me get into it.
Unfortunately none of them fit the screws. The screwdrivers are 0.8mm, 1.2mm and 1.5mm, and the screws on my Macbook seem to be between 1.2mm and 1.5mm.
What's confusing me is that according to Wikipedia, there is no pentalobe size between 1.2mm and 1.5mm.
Am I going mad?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 1개
선택된 해법
No, I don't think your mad, but maybe on the cheap side ;-} Sounds like these drives are not well made. The technical name for the size is P5 Pentalobe we really don't get into the dimensions of the bit.
You may want to use a pick to make sure the screw head is not filled in with junk. Also, Apple uses thread-seal, I often need to use a soldering iron to head up the screw (don't get any solder on it) to soften the thread-seal a bit to get the screw loose. The last action is a drill if the head is damaged or sheered off. Just be careful with the metal shavings!
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
귀하의 답변을 추가하십시오
Chris White 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 39
30일 전: 129
전체 시간: 5,845
