My iPhone won't turn on...
Like it said on the title, my iPhone won't turn on. I tried sleep/home button but only apple logo would turn on for 3 seconds and black screen.
좋은 질문 입니까?
좋은 질문 입니까?
If it only turned on for 3 seconds, it has nothing to do with the system itself. Probably has to do with the battery, try plugging it into a lightning cable and turning it on.
If that doesn't work, plug into iTunes hold the home button while it starts up and try to put it into recovery mode. if iTunes recognizes it then hold the home and power for 5-10 secs till you see the screen turn off and then back on again.
What ios version is it on? and is it Jail broken? Sometimes a tweak could be causing it to crash on boot and you may need to boot into safe mode. depending on what ios version your on it could have a different way of getting into it. Safe-mode is something that was installed if you installed cydia substrate.
If you still cant get it to boot up regularly or into safe-mode, your best option is to restore it and restore from back up either via icloud or itunes
해당 답변은 도움이 되었습니까?
I tried a lighting cable and does not work and itunes sign won't even show
do the hard reset (Home+Sleep), while plugged into iTunes. When it shows the apple symbol, let go of the sleep but keep holding the home button. It should show a apple symbol now, and be in restore mode. Click on restore in tunes and restore it.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 130
댓글 2개
Iphone 5s, and it charges but it's black screen
Hyosik Bang 의
@oldturkey03
Hyosik Bang 의
