Why can't I answer my phone?
Phone rings and i swipe right, left, down, etc...have not been able to answer phone ever since it arrived....
좋은 질문 입니까?
좋은 질문 입니까?
This took me forever and i still don't know how it happened but, go to you SETTINGS, then go to APPS should be under the category DEVICE but it shows all the apps on your phone, then scroll down to the app that you use to make calls should simply say PHONE (side note make sure this app is set to DEFAULT), click on it and scroll down to where it says NOTIFICATIONS, there make for sure your BLOCK ALL option is off and at least TREAT AS PRIORITY or ALLOW PEAKING option is ON... Hope This Help You Or Someone Else... It's What Happened To Mine I Don't Know How And It Sucked...
해당 답변은 도움이 되었습니까?
VERY GOOD. My Blu G60 manual was useless to solve problem
I think you should check updates for your phone and if it doesn't solve the problem, then the problem is in the phone's firmware. try to contact tech support.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 10
30일 전: 58
전체 시간: 5,722
댓글 2개
I have this problem too
satanismycat 의
Can't answer phone when someone is calling
Victor Lopez 의
