메인 콘텐츠로 스킵하기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
3347 질문 전체 보기
no power to any connector
hi there I have a strange case here !
my iphone was working great but there was a problem with the dock connector so I bought one from I fixit and changed it but after that , there is no power reaching for any of the connectors ! ,what I mean when I plug a charged battery the phone powers on but no screen of curse and no sound and no power button or any other button working !
but when I try to call it the other phone used to call shows me that's it is ringing and when I unplug the battery it hangs up so it is working but with none of the connectors inside working !!!
what is the problem ?
ps. I accidently hit the motherboard with a screw driver near the battery connector by mistake !
please help .
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
mohammad khalefa you've checked the components around the battery connector. Sounds like something got shorted out.
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
가장 유용한 답변
Did you unplug the battery before and during the repair?
It sounds like you blew a filter/fuse on the display circuit. If you plug the phone into a computer, does itunes or windows see it?
If so, you will need to replace the damaged component. This does require micro soldering skills.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
no this is not it ! I told you there is no screen , no power connector , no buttons working nothing .
the circuit for the inside connectors is broke (that's what I see) but where is the problem ?
의 답변
OK....its not it. Sorry for trying to pass on 17 years of experience.
의 답변
sorry what i meant is , the phone does not charge or power up because non of the buttons work there is something wrong with just like you said a fuse or something but the problem is who can do such a micro soldering around here :(
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
mohammad khalefa 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 55
