주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone 6 doesn't recognize charger but charges to 1% only
Hello everybody!
So I have this issue with my iPhone 6. It doesn't recognise the charger when plugged in, but suddenly turns on with 1% battery only. During these few minutes it is on, it still doesn't recognise the charger nor it charges. So it basically dies again to charge to 1%. This goes on and on.
Do you maybe have the same experience? It is out of warranty therefore "bring to Apple" answer do not help :/
Thank you!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Sounds like a fried U2 IC. Charging to 1% and no further is one of the symptoms. Try a new battery. If that doesn't work, then it's probably a board-level issue. I don't think it's the charging port because the phone will charge to 1%.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
This is probably the case. the charging current with a fried U2 IC can be almost 0 amps to a very low amperage like 0.20 or less amps. Which when the phone is on will probably already use up that power.
Seen it happen on Samsung phones too but usually on the power IC chip side instead of the charging one.
댓글 달기
It could be a bad battery or charge port. Have you tried replacing these? Also try multiple cords, if the cord is bad it may only charge intermittently.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Johannes Guttenberg 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 1,036
