주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
295 질문 전체 보기
My new digitizer's bottom half of the screen is not registering touch.
My new digitizer's bottom half of the screen is not registering touch. What is wrong? The top works fine. but if I were to input a passcode in landscape for example. I can't touch the 3,6, or 9.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
Edric Chen,
it should be digitizer defective. you may have to replace the digitizer
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
If you can reseat that digitizer connector by pulling it out and putting it back in, you'd be surprised how many problems that solves. :)
It's worth noting, that if your iPad had any power at time of replacement, erratic behavior can occur. I recommend you hold both the Sleep/Wake and Home buttons for at least ten seconds, until you see the Apple logo, before considering the digitizer defective.
해당 답변은 도움이 되었습니까?
점수 2
2 댓글:
OP: If you do intend on opening the iPad Air yourself you should have a digitizer ready just in case you crack the glass as it requires heat and a lot of patience in taking the glass off and using the right tools.
I have reseated it multiple times to no avail.
댓글 달기
sounds like a defective digitizer, have you tried possibly a new digitizer or the old one if it didn't have any touch problems
해당 답변은 도움이 되었습니까?
점수 1
2 댓글:
Just tried the old one. Didnt think of doing that for some reason. That one works so the new one has to be defective.
yeah thats what it looks like, see if you can return your defective part or exchange it for a new one, where did you buy the digitizer?
댓글 달기
귀하의 답변을 추가하세요
Edric Chen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 1,396
