주요 콘텐츠로 건너뛰기
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
58 질문 전체 보기
whether capslock is on or off on keyboard
'''how do i know whether capslock is on or off on my ASUS keyboard because there is no sign related to it
i am too confused
please help me
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 9개
sala kaam hota h lkin khada he nh hota lodu laptop h
I have this problem too - why isnt there a light to tell you about num lock like there is for cap lock - have no ideawh at scroll lock does but page up and down never work.
what i mean is my asus has a light on the caplock key to show cap lock is on - doesnt yours?
Mine does not either. :-(
Mine neither. Big problem when you are entering a secret code...
댓글 4개 더보기
댓글 달기
답변 2개
선택된 답변
Hi,
Try the following:
Go to Control Panel > Ease of Access Centre, scroll down to Make the keyboard easier to Use
Check the Turn on Toggle Keys checkbox.
Click Apply > OK.
Now you will hear a tone when you press Caps Lock, Num Lock or Scroll Lock. Windows will play an alert beep warning each time you press the Caps Lock, Num Lock, or Scroll Lock keys. These alerts can help you prevent accidentally pressing this key.
해당 답변은 도움이 되었습니까?
점수 13
댓글 4개:
Thanks for the tips regarding the toggle key setting for caps lock
Thank you! It was exactly as described.
How to turn on this sound on ubuntu?
It was a very very useful tip.. as well in the background of increased need of complicated passwords, this option is very very useful... thanks for the tip
댓글 달기
The best solution:
http://cli.jonaskohl.de/
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Really HELPFUL little utility for folks w/ cheep laptops w/o keyboard indicators.
댓글 달기
귀하의 답변을 추가하세요
Shivani Nathany 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 15
30일 전: 115
전체 시간: 40,177
