주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
MacBook 제품군은 2006년 5월에 처음 소개되었으며 Apple의 가정용 노트북 iBook을 대체하였습니다.
4479 질문 전체 보기
Is this worth fixing?
3 days ago, My Macbook started crashing (giving me the Gray Screen of Death), but as long as I keep the internet off, it wouldn't crash. Last night my computer just shut off and now isn't turning on. Macbook doesn't even turn on. I push the power button, and the sleep light on the front comes on, but nothing happens. The screen stays black. No chime or tone or anything. It wasn't dropped, nor was anything spilled on it. My computer is 4 years old.
I tried unplugging it and remove the battery and holding down the start button for ten seconds. Still nothing. I also tried starting up from my system installation disk, still didn't go any further. and now my disk is stuck. Another thing I tried is starting up holding down the Option & Command and P and R keys. Still nothing.
The last 3 numbers of my S/N are U9C
I think it's a power control issue. Maybe I'm wrong on that? is it easily and/or cheaply fixed, or is this part of the logic board?
If it is the logic board, is it worth replacing on an old, 4 year old computer or just get a new one? I'm really at a loss for what to do here!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
This question seems very familiar. Did you erase the first question and my answers?
The first one had gotten off track, hard for me to follow, and wasn't really answering my question. So i deleted it, compiled all the info here, and though I'd try again to see if i can get a more concise and applicable answer... I've tried just about every trick in the book that anyone and every has suggested (before anyone suggested them on here), thats not what I need help with. I need to know If I'm right in the power control board/Power Management Unit being the problem (not the AC Port), and if it is, is it easily and cheaply fixed or is the computer pretty much gone?
의견 추가하세요
필수 도구 키트
최고의 소형 키트에서 가장 유용한 도구.
지금 쇼핑하기
필수 도구 키트
지금 쇼핑하기
답변 1개
선택된 해법
You have a :Apple MacBook "Core Duo" 2.0 13" (White) Specs
Identifiers: MacBook - MA255LL/A - MacBook1,1 - A1181 - 2092
First there is no separate part called a "power control board". The AC adapter (MagSafe) connects to the MagSafe DC-IN Board Apple part (922-7384). This connects to the logic board.
Here's a blow up of all the parts: http://ep.yimg.com/ca/I/lovemacs_2127_24...
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Ok, so it's not a quick/cheap fix. That's all I needed to know!
Well it's a relatively cheap fix at $28 +. It takes me about 30 minutes to install one. Here's the part: MacBook MagSafe DC-In Board
Here's how to do it: MacBook Core Duo MagSafe Board Replacement
의견 추가하세요
귀하의 답변을 추가하십시오
Joel Cornett 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,653
