주요 콘텐츠로 건너뛰기
Apple Cinema Display는 모델 번호 M8149가 특징이며 2000년 7월에 처음 출시되었습니다.
7 질문 전체 보기
Voltage inverter, backlight inverter.
Is the voltage inverter the same as the backlight inverter?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
3 Comments:
Blackfalcon911 in what context did you hear the term voltage inverter?
There was an instructional on ifixit, how to remove the voltage inverter on the cinema display. I was just wondering if this was the same inverter that controlled the backlighting?
The backlighting on my cinema display is darker at the top of the screen, it flickers and i read it was the inverter board.
댓글 달기
답변 2개
The back lit screen is just this. It has screen film that is constantly changing color and brightness in thousands of pixels. But the screen does not light up we have to let the light pass thru the screen film so we can see all this magic.
This light comes from small long fluorescent tubes located around the sides of the screen. There can be two or more and like a household light it requires a voltage inverter to step up the voltage to fire up the tubes.
I have a feeling one of your tubes is faulty as in my experience one inverter can light two tubes. this means the bottom half light is working and the top light is not. If you have dropped your display it may have broken the tube or even severed the wires . Or I could be wrong and this display has two inverters one for each tube. Could be 4 tubes and you get the picture. You have to decide wither to take it apart and see what is going on inside and replace a faulty inverter or tube but for the age of the unit a shop price would out weigh the cost of a new one. Or a second hand one is another option.
Good luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I would suggest if you buy another second hand will save you money and headache.
The simple answer for the question is
The voltage inverter and backlight inverter can be the same where and how the person described the item.
As for me, I call "Backlight driver" and the power supply or power control unit for the machine. So I would say it might be the same or different depend on how the person think.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Blackfalcon911 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 207
