Repair guides and support for the Expedition, a full-size SUV based on Ford's F-150 pickup truck. Closely related to the Lincoln Navigator.
32 질문 전체 보기
Why does the transmission of my expedition break and go repeatedly?
The back wheels of my 1999 Ford Expedition break, then release then breaks again in a repeated cycle. I believe it's the transmission because I disconnected the breaks and it continued to do that. If so what can I do to try to fix this ?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
This sounds like a pinion gear in the rear end. to test this raise the rear end so both tires are off the ground then put the truck in neutral and spin the tires if there is a binding on every few revolutions this is your problem . Another test would be to crawl under and see if the drive shaft will move up and down at the yoke just by pushing on it , or if the rear end is wet from the seal leaking. Hope this helps
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
귀하의 답변을 추가하십시오
Mariana 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 66
