주요 콘텐츠로 건너뛰기
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6은 Galaxy 라인의 다음 주력 제품입니다. 곡선형 스크린 버전은 Galaxy S6 Edge로 알려져 있습니다.
487 질문 전체 보기
Pulsing blue light and black screen are keeping it from turning on
My phone fell. The screen is not cracked however the screen is black and the blue light dims in and out. The phone charges, as indicated by the red light when plugged in. Is there any way to get it to turn on?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 3개:
Plug it into your computer and see if the computer recognizes it. If it does, its just a display issue. Follow the guide to remove the screen and make sure the LCD connector is seated properly. If it is, you just need a new display.
I plugged the device into a computer (via the charger) but the computer does not recognize, or say that the phone is in.
Hey did you get it fixed? What was the problem?Same thing happened to me yesterday and i am confused.
댓글 달기
답변 2개
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
same problem here, how did you fix it ??
댓글 달기
You would try a soft reset press volume down and power button together for a few seconds to see if it boots up failing that u would try a new screen
Heres a handy dandy guide on replacing the screen
Samsung Galaxy S6 Screen Replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Stacy Walton 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 38
전체 시간: 9,881
