주요 콘텐츠로 건너뛰기
Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
96 질문 전체 보기
TouchID and Home Button not working after replacement
Hi,
I order from a seller on eBay a iPad Mini 4 LCD/Touch replacement. I saw that it has to desolder and solder again a flex that connects the home button to the assembly.
After the replacement and transfer for this flex the home button will not work, but if I solder it again to the broken one. It will work flawless. any one had encountered this issue?
I test the same procedure on 3 different replacement LCD/Touch assembly and in neither will work, only on the original broken one.
Any help will be thanked!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
The home flex cable may be torn??
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Robert G 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 736
