주요 콘텐츠로 건너뛰기
The battery doesn't take charge. What can the problem be?
Hi, I have a tablet samsung galaxytab3, the battery doesn't take no more charge. I don't know to buy a new one.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Have you tried a different charger?
댓글 달기
답변 2개
It is likely to be the battery. There may be mobile phone repairer in your area that can replace it. You can do it yourself if you have the skills. Here is a youtube video on how to do it: https://www.youtube.com/watch?v=_I2uLqRg...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yesterday a was fixing a similar problem and it was the connector that plugs in to the logic board. This battery as clearly been reworked at the factory even though the unit was sold as new. The unit wouldn’t start and constantly cycle on off and didn´t charge. We took the battery out and charged directly with some pins. When we put it back we notices that notices that there was only 1.5 volt on the board and 4 volt on the tabs when the unit tried to boot up. On the battery tabs there was 4 volt all the time. I followed the voltage drop to the connector and found two dodgy pins on the negative terminals.
Update (02/22/2019)
I hope the image loads this time.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
estimablej 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 67
