주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Not working after screen replacement
Had a cracked screen on iPhone 5, so replaced it.
Switched it on and left side of screen was white, right side black.
Opened it back up and checked everything again, but now nothing happens at all?
No lights, no Apple, no noise or vibration, just blank.
Now I'm going blind from squinting at small screws and parts and having a minor tantrum, any ideas before I start chucking it about?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Make sure you have the battery unplugged at all times when replugging the front panel connectors. Make sure they click in properly when plugging them in.
That issue is usually caused by a bad connection from the LCD ribbon cable to the LCD connector on the logic board.
Additionally you can try cleaning (with 99% isopropyl alcohol) the front panel connectors on the logic board and the LCD and digitizer ribbon cable coming from the front display assembly (screen).
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Took it all apart and reattached all connectors, still nothing.
Have put it on charge in case battery is flat, but no sound or vibration you usually hear when charging, and screen is still blank.
Did you find a fix Linsey?
댓글 달기
귀하의 답변을 추가하세요
Lynsey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 57
