Why does my connect keep switching on and off
My kinect keeps switching off and needs to be unplugged and replugged in for it to work. When I am on the kinect settings the camera keeps switching on and off. Any suggestions as to the problem?
좋은 질문 입니까?
댓글 7개
I have the same issue. Started about a month ago. Have to unplug and reconnect each time. Its a pain as I use cortana quite a bit.
Royhid Ravi Rana 의
Have you found a solution? my kinect is with the same problem, it is probably overheating, his fan does not turn on
LuccaBR1 의
For PC - check to see that the kinect audio input is enabled in sound settings, "Manage sound devices". This was causing the problem for me.
Dan Brinks 의
@thinkfastdev wow bro you just saved my streams! thank you!!! I was going crazy already trying to understand whats up))
DMG Dooly Media Group 의
I would suspect the three SMD electrolytic capacitors under the shield next to the cameras.
infiniti25 의
댓글 2개 더보기
