주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
iPhone 6S 'no sim card' after charging port replacement
Hi
I'm having quite some trouble replacing the charging port on an iPhone 6S. I have 2 devices with a broken port, I replaced the flex cables just like in the previous models, no big deal. But both devices started acting really strange:
When no SIM card is installed, the device continuously displays the 'no sim card installed' dialog, with intervals of 10 seconds.
When a SIM card is installed, it searches for signal for half a minute, then it just displays 'No signal' in the corner. Also, when going to settings, the carrier - option continuously appears and disappears from the menu.
All symptoms disappear and the SIM card functionality returns after disconnecting the charging port or plugging the old (OEM) charging port back in.
Does anyone have any idea how to get around this issue?
Regards,
Laurent
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개
I don't think you're going to be able to get around the issue, you're probably just going to have to get another lot of ports. good luck
I think he just got a bad batch of charging port. The chances of this increase significantly depending on how much you pay for the part.
You really need to keep your anti static bracelet on, even after the battery disconnect, it seems more like a short or arc elsewhere or secondary would be the charge port. A really good cleaning may have to be a priority.
댓글 달기
답변 1개
가장 유용한 답변
You may have to check the proximity sensor, it may have been damaged at some point in the repair, it shows satellite signal as well as multitude of other functions.
Good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
iPhone 6s plus no sim
댓글 달기
귀하의 답변을 추가하세요
lorre851 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 764
