주요 콘텐츠로 건너뛰기
Headphones released in 2011 for use with XBOX 360. They are identified by the model number X12.
26 질문 전체 보기
How can I splice my wires back together?
My cat chewed through my headset. I can see all wiring but not sure how to get them back together. It was chewed through above usb port and below the jack that plugs in to the controller.
Update (09/01/2016)
Picture of what the wires look like
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
As long as you know what wires connect you each other you will be fine. If you have access to a soldering iron, that would be your best bet - simply solder them back together, ensuring that you keep each different color completely separated from the others and then using electrical wire or heat shrink to cover each individual color.
What ever you do do though, it isn't going to look very neat anymore unfortunately.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Trey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 711
