이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 4개:
there could be several reasons to why it doesn't charge but the most common are bad batteries, water damage, broken charging port. all three of these are recommended techs only to fix so i'd take it to my local repair agent and get them to have a look. good luck
Hortman 의
Peppe, what do you mean by this "with the connector does not happen charging"?
oldturkey03 의
The USB port is ok
He did not take water
Peppe 의
the battery if the load with bench power supply accepts the charge
the problem is that you do not see the charging status
Peppe 의
