This is a stainless steel, 4 slice toaster oven. The model number is located on the bottom of the device. It has a single rack height and a removable crumb tray.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
@rotorgrl not quite sure what you are referring to. Same Black and Decker TO1303SB? Post some images of what you have going on there, so we can see what you see. Use this guide 기존 질문에 이미지 추가하기 for that.
oldturkey03 의
