주요 콘텐츠로 건너뛰기
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6은 Galaxy 라인의 다음 주력 제품입니다. 곡선형 스크린 버전은 Galaxy S6 Edge로 알려져 있습니다.
460 질문 전체 보기
Samsung Galaxy s6 only charges through a computer
My samsung galaxy s6 only charges through a computer and not through an outlet. I had encountered this problem last week and fixed it with a factory reset. It then worked for an entire week and suddenly, today, it stopped working again. I hadn't downloaded anything new nor changed anything and yet the problem occurred again.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Hi, Have you tried a different power adapter?
의 답변
yeah ive tried multiple chargers with multiple adapters which worked with my other samsung devices. I don't believe that it is the chargers.
의 답변
의견 추가하세요
안드로이드 수리 키트
A new screen or battery is one kit away.
지금 장보기
안드로이드 수리 키트
지금 장보기
1개의 답변
Hi
I got the same problem and was so upset bc all my battery 0% I cannot access to anything, I finally got this idea to connect my phone on the pc then proceed these step below:
Try disabling the USB debugging mode from the developer option settings.
Tap Settings.
Tap on “About Device” menu and then tap on “Build Number” 7 times.
You will get a prompt that says that you’re a developer now.
Go back to the Settings menu then tap on Developer options.
From the Developer options, uncheck the box that says USB Debugging.
which this could help some :)
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
bangtanly2000 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 23
전체 시간: 2,477
