주요 콘텐츠로 건너뛰기
HD action camera with touchscreen LCD, released October 5, 2014.
87 질문 전체 보기
How to fix my go pro4 silver edition
How to fix my gopro hero4 silver edition?...last week during our island hopping i forgot to change the back cover of my camera since im using my dome. But i noticed immediately that its not the back cover supposed to be used. I removed the battery and the micro sd card! And soak it in rice for a day. A day after i tried to turn it on and it work, but the back LCD is not not functioning. Please help solving this problem! Thankyou and Godbless....
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the camera's operating design and could damage the components. Rice is good to eat but does nothing to fix the corrosion caused by water and electricity.
First you need to remove the battery from the camera.
Then you need to dis-assemble the camera and clean all the parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water.
Here is a link that in general, describes the process.
Electronics Water Damage
You will probably have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the camera might possibly work correctly again
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Its been a week now, i tried to turn it on! Its still working but the back LCD is dead!....
댓글 달기
귀하의 답변을 추가하세요
Jobar jay chan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 184
