주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Strange behaviour after replacing battery
I replaced a bad battery on my iPhone 6. The process went fine, and when finished the phone came on with nearly a full charge. However,
(1) the phone won't charge.
(2) plugging in a lightning cable usually does not cause the phone to charge, but bending the plug a little in the socket will cause the charge indicator to come on.
(3) even when the charge indicator is on, the new battery does not charge.
I'm wondering whether a bad battery may cause these symptoms. I would think it could be a problem with the lightning connector, but the fact that the battery doesn't charge even when it says it should be charging is strange.
Anyone run into this before?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
댓글 달기
답변 1개
선택된 답변
Sounds like a bad charging port.
If you have already tried multiple cables then I suggest changing the charging port.
And yes I have encountered the same issue before on a iphone 5s and used the same troubleshooting steps.
Thought it was battery initially, replaced battery, percentage never goes up just goes down. Changed charger port and it charges now.
I think the faulty charger port killed my old battery.
Probably the same result for yours too so better to keep the new battery in.
What kills the charger port? Probably cheap lightning cables and/or wall adapters. The good cables are the ones that are mfi certified.
Guide to replace charging dock: iPhone 6 Lightning Connector Assembly Replacement
Where to get the part if you prefer to buy from iFixit:
iPhone 6 Lightning Connector and Headphone Jack
Try cleaning the charging port with a toothpick or something equivalent if the charging cable does not plug in fully.
iPhone 6 Lightning Connector and Headphone Jack 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Tim Wentworth 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 136
